Status
Not open for further replies.
1 - 17 of 17 Posts
After seeing a ton of threads in just the past week all asking about tuning an lml I decided to start this thread that can be referenced instead of retyping the same thing over and over. Some of these will be my own threads I started when I was a noob. Feel free to add to the list.
-Air intake and filtration
Q. Do I need a cold air intake (CAI)?
A. No. The stock intake assembly offers better filtration than any of the aftermarket assemblies. However, aftermarket CAIs offer improved air flow, slight increases in fuel economy and support high power engine builds.
Q. Best cold air intake?
A. aFe stage 2 (Joker's pick). Personal preference plays a big part here.
Reference: http://www.duramaxforum.com/forum/general-discussion/155262-best-intake.html
Q. Dry or oiled air filter element?
A. A dry element will offer good filtration, excellent air flow and requires next to no maintenance. An oiled element will offer excellent filtration, good air flow and requires minor maintenance. An over oiled element will lead to fouled sensors downstream of the filter. Mass Air Flow (MAF) and Manifold Absolute Pressure (MAP) sensors may need to be cleaned more often when using an oiled element vs. dry.
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/145874-check-engine-light-2011-duramax-lml-afe-cold-air-intake.html
-Fuel
Q. Best fuel additive?
A. IMO opti lube.
Reference: http://www.duramaxforum.com/forum/general-discussion/157405-fuel-additive-poll.html
Q. How do I change my fuel filter?
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/139151-how-fuel-filter-change-procedure.html
Q. Best fuel filter?
Reference: http://www.duramaxforum.com/forum/general-discussion/158064-best-fuel-filter.html
Q. Should I pre fill my new fuel filter before I install it?
A. No. It lets unfiltered fuel into your injectors.
Reference: http://www.duramaxforum.com/forum/maintenance/187329-fill-new-fuel-filter-not-fill-question.html
Q. What is the best lift pump?
A. Personal preference.
Reference: http://www.duramaxforum.com/forum/general-discussion/174994-fass-ad.html
-Transmission
Q. Best transmission fluid?
A. TranSynd.
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/153228-best-lml-tranny-fluid.html
http://www.duramaxforum.com/forum/general-discussion/158307-transynd-vs-amsoil-torque-drive.html
Q. Tranny fluid change intervals?
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/154687-tranny-fluid-change-intervals.html
-Engine oil and maintenance
Q. What is the best oil?
Reference: http://www.duramaxforum.com/forum/alternative-fuels-diesel-additives-lubricants/149663-brand-oil-do-you-use.html
Q. Best oil filter?
A. IMO amsoil
Reference:http://www.duramaxforum.com/forum/maintenance/138122-best-oil-filter.html
Q. How much oil should my truck use?
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/157843-lml-oil-usage.html
Q. My oil pressure is fluctuating, is that normal on a Duramax?
A. Yes.
Reference: http://www.duramaxforum.com/forum/gauges-electronics-wiring/177218-duramax-oil-pressure-fluctuating-lot.html
-Tuning / monitoring / engine management
Q. Is the DIC accurate?
Reference: http://www.duramaxforum.com/forum/general-discussion/157192-dic-use-not.html
Q. Best tuner for the lb7 through the lmm?
A. Efi live.
Reference: none needed.
Q. Is there a warranty friendly lml tuner?
A. NO!
Reference: GM. Companies like edge are saying they have a lml tuner that will not void your warranty, they are lying to you.
Q. Will a dpf present tuner give me better fuel economy?
A. No.
Reference: http://www.duramaxforum.com/forum/07-5-2010-lmm-duramax-powertrain/172954-2011-gmc-lml-delete.html
http://www.duramaxforum.com/forum/performance-upgrades/173906-2013-gmc-2500-hd-6-6l-programmers.html
Q. Best efi tune writer?
A. Idaho Rob Coddens (ATP trucks) Nick Priegnitz (Duramaxtuner) Mark Broviak (Danville Performance)
Q. Best lml tuning?
A. H&S until kory is finished and then we will have to see how it holds up.
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/159293-official-lml-tuning-dyno-thread-kory-willis.html
Q. Can I delete an lml?
A. Yes, but you have to find and h&s tuner that will delete.
Reference: http://www.duramaxforum.com/forum/aftermarket-mods/173538-deleting-lml.html
Q. Where can I get a h&s delete tuner?
A. Ask the site vendors.
Q. What is a edge insight?
A. Its a monitor that will read your trucks trucks computer and show you your actual temps and reading because your stock gauges are are very inaccurate.
Q. Will a edge insight void my warranty?
A. No, its only a monitor.
Q. Should I get a h&s mini maxx or the xrt pro?
A. Xrt pro with an edge insight to monitor with, bigger screen, more gauges.
Reference: http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/178146-mini-maxx-xrt-pro.html
http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/169154-xrt-pro-vs-mini-maxx-race-tuner.html
Q. If I decide to change tuners do I have to reprogram my truck back to stock with the old tuner before I program using the new tuner?
A. Yes
Q. Can I tow XXXXX lb trailer on "insert high HP tune here"?
A. Yes.
Results: you will destroy stock transmission components if you are not careful
a monitor will make things easier but not idiot proof
If you have to ask on the internet, you shouldnt do it
Please don't make a thread about your specific trailer weight and tune because JOKER will come unglued on you :thumb
References: http://www.duramaxforum.com/forum/towing-hauling/176554-towing-120hp-tune.html
http://www.duramaxforum.com/forum/efi-live/162906-tow-tune-max-hp.html
http://www.duramaxforum.com/forum/efi-live/162763-tow-tune.html
http://www.duramaxforum.com/forum/transmission-shop/158075-how-much-power-can-i-tow.html
http://www.duramaxforum.com/forum/towing-hauling/166706-how-hot-2.html
http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/158277-towing-what-tune.html
-Wheels/brakes/hubs/wheel bearings
Q. What is the bolt pattern for my truck's wheels?
A. -LBZ to LMM, both SRW and DRW = 8x6.5" (165.1mm)
-LML SRW = 8x180mm, DRW = 8x210
Q. What is the lug nut size?
A. 22mm
Q. What is the lug nut torque specifications?
A. 1500-120 ft/lbs
2500-140 ft/lbs
3500-160 ft/lbs
-Miscellaneous fluids/filter questions
Q. What should I do to my truck? Which modifications are popular?
A. Educate yourself about the available modifications, both aftermarket and DIY, then choose which suit you.
Reference: Some helpful build threads.
http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/121510-my-build-thread.html
http://www.duramaxforum.com/forum/2011-up-non-powertrain/162294-my-lml-build-thread.html
http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/129007-lml-build-thread.html
http://www.duramaxforum.com/forum/2011-lml-performance-parts-discussion/140320-off-road-dually-build.html
Q. Best rear diff fluid?
Reference: http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/157149-best-rear-diff-fluid.html
Q. Will the same oil, tranny, and fuel filters fit any Duramax?
A. Yes.
Reference: http://www.duramaxforum.com/forum/maintenance/176050-lml-filter-questions.html
-Forum (posting, editing, viewing and voting)
Q. Why cant I post in the for sale section?
A. You must have 25 post before you can post in that section/you must also list a price with your add.
Reference: http://www.duramaxforum.com/forum/new-here-please-read/29232-welcome-df.html
There is a lot I have forgot and left out but I will add as it comes to me, feel free to post any others.
Right now I am working in conjunction with my good friend JOKER to organize this under headings for different things so that it will be easier to navigate and find help on. There is a lot left to add so keep checking back for updates.
Ask one to be one
This is a great idea. Please if there is something that you would like added to the list post it up. All other posts will be removed so we can keep this thread open and clean.
I am also making it a stickey so it stays on top.
I would like to say thanks to my good Canadian friend JOKER for going in and adding all of the headings and color, adding some things that needed to be in there, and for also putting everything under the correct headings. Looks great pup bro :thumb
Nice write up!!
Thanks
I need the HELP!
First diesel pick-up ever owned so I don't know the diesel lingo yet.
The truck is used mostly for everyday use and this diesel lingo is all new to me and confusing, but I'm still learning.
Please help this newbie with lingo an idiot can figure out.
Thanks in advance.
I need the HELP!
Thanks in advance.
FPRV (fuel pressure relief valve)
FPR (Fuel Pressure Regulator)
CP3 or CP4 (GM's name for the High pressure fuel pump)
PCV (positive crankcase ventilation)
MAF (mass air flow sensor)
DTC (diagnostic trouble code) (check engine light)
CC/SB (crew cab/short bed)
Black Smoke (stupid)
I am sure there is more but I cant think right now...
1 - 17 of 17 Posts
Status
