I ordered a Fass 95gph lift pump but the shop mis ordered and installed the 165gph instead. My 07 lmm has dpf delete. Idaho Rob efi live tune. I run mostly in the enhanced stock tune and use the 40hp for pulling 5r. Long road trips empty i use the 80hp (get. pprox 1.5gpm more) should I have shop get the 165gpm replace with what I really wanted? Just seems like a waste of circulation. Found out pump motors r exactly the same on both units just different pump.
if there charging you the 95 price for the 165, roll with it, if they want to charge you for the 165, make them fix the issue. The only difference is the number of times an hour the fuel tank will be filtered, 3 times on the 95 and 5 times on the 165. Your engine will only consume as much fuel as it needs regardless of the size of the lift pump.
Sorry to hack your thread, I just want to ask you something, I have the CP4 and I've been reading on this to make sense of the issue, to avoid an issue on my 2016 Dmax, should I use a lift pump and additive? It seems everyone has a different opinion on this, my truck is bone stock and not planning on doing any tunning or deleting for now, I just came out of warranty and want to avoid a catastrophic issue, have a kid in college and dont have the extra $ to spend on not essentials, you seem to know what are you talking about, please advise.
I was reading on Bio Diesel, do I have to change anything to be able to run it? they were people saying that the Bio will clog the original filter due to getting all the gunk out from the previous diesel.
i have never experienced any issues, nor did i have to change anything. Im not talking about home brew diesel here though in case that was not clear im talking about professionally manufactured biodiesel at a gas station. No changes are needed to run it. If you are distilling your own diesel from cooking oil (your nuts) but then yes you will probably want some additional filtration to get the old tater tots out before the injector. >
But if I'm only filtering 3 gph instead of 5gph wouldnt my filters last longer and less wear on pump as it only doing a third of the work so it too might last longer?
I would venture to say that the filters may see more debris since it is circulating more but you also got to figure that since its already been filtered previously it shouldn't have that many contaminants in it to make a noticeable difference in filter life. As far as the life of the pump goes anything can happen but i saw a video where i believe it was air dog that had a pump at their shop that logged thousands of hours on it and it was still going running 24/7.
If they even have bio available, Phx ain’t gots bio.
Aux tank has a 40 micron inline filter to my main tank.
The Baldwin LP filters for my AirDog 100, that I have on now, LP 10 micron, LP 20 micron WS, stock filter 4 micron with WIF sensor.
AirDog 100 & FASS 95 both are good for up to 600 hp.
The up-to 500 is a sales pitch to sell a larger LP which in some cases your stock pick-up can’t handle that much “sucking”.
You might have the 1/4-1/3 tank issues, plenty of chatting about this, where you’ll end up drilling a large hole in the bottom of your tank for a sump, or put a smaller LP motor on.
My choice was the 2nd one, I went from a FP100 too a 4G165, then to a 4G100, after I had these well known issues.
Besides these issues the fuel psi went from about 7-8 with the FP100 to 12-13 with the 4G165 (to high) back to 8-9 with the 4G100.
No psi adjustments on my LP.
