1 - 11 of 11 Posts
So I got all the injectors out waiting on my new ones (suppose to be here day after tomorrow) any hints or ideas on the first steps i need to take BEFORE i try turning it over for the first time? I have a new filter on and all that jazz but how do I prime these bad boys? IM NERVOUS lol this has been no easy project these lb7's are a real B!tch to change injectors on...:help
Im Superrrrr!
prime prime prime, bleed.....
Repeat a few times til the primer is about as hard as its gonna get....
Then crank it over in bursts of 5-10 sec max...let it cool for a few seconds.
Might take 3-4 cycles of cranking to get all the air out.
alright, im assuming bleed them at the fuel lines closest to the valve cover? I appreciate the help!
getting ready to change mine as well any special tools or hints
Isn't there a fuel line tool needed also? I'll be changing my i njectors in the next couple of weeks and I thought I read where a fuel line disconnect tool is needed........
NO these are high pressure lines (up to 23,000 psi).
Just use the bleeder screw at the fuel filter housing.
injector sleeve ?
i have been told that there is an injector "sleeve" at each , filled with or surrounded by coolant . it is important that the "sleeve" not be disturbed if possible when un-screwing each injector . try not to have the sleeve un -screw. other wise you have to replace the sleeve as well . which are added parts/labor $$$ . does this sound correct ?
thanks marc
kinda, you can't really un screw the injector. I lucked out on mine and all the injectors came right out. I am having other issues though if your interested its on another post I did. Changing the injectors wasn't bad itself its the problem I'm having now that sucks.
I'm hoping mine is within the extended warranty so I don't have to do this myself. It scares me. lol best of luck to you.
1 - 11 of 11 Posts
