1 - 19 of 19 Posts
Yeah the truck is insane, just needed some prep work before pulling. I been working pretty much 5 to 8 all last week so i only had time to toss together some quick bump stops that didnt even hold up
whats she pushing?
hp wise
Wait so you bought Idaho robs truck?!? :)
Slave to the Interwebs
Rob called and wants his stickers removed....LOL
Not bad for your first time. I do not think I would do that good. You will get better once you learn how far to push the skinny pedal.
you betcha :D
Gotta get some real bump stops installed, and let the tire pressure out and the T bars down some and it should do a lot better. been so swamped at work and just picked the truck up. all i really had time to do is change the engine oil
I'm sure there are front end modifications but what has been done exactly? Great pull.
Once you drop the psi in those tires it'll be as smooth as a oiled stripper on a slip n slide.
1 - 19 of 19 Posts
