1 - 7 of 7 Posts
well fellas it was my first time out at the track like the sig says i have a 05 crew cab long bed dually it only had an 80 hp tune becuase of the stock tranny but here is my fastest time tell me what you guys think
60ft-2.259
330ft-6.257
1/8-9.595
1/8MPH-73.99
1/4-14.937
1/4MPH-91.43
now it is a dually it has 235/75/16's its only 2 wheel drive (4X6):D but i couldnt hook up for the life of me as soon as i got into any boost at all it broke loose everytime at the line and ould burn thru 2nd gear. well what do you think about the times and what can i do better
Those are good times considering all that you have going against you. If you intend on getting serious i would upgrade the tranny and look into slicks then dump the power to her.
Try and get your 60' time down (better launch) and your ET will come way down without increasing power.
thats the lowest i could get it i need to get some valve stem extenders so i can let the preassure down in the back i was at 80 psi and i put air in the tires without taking them off everytime i tried building boost and then going it just spun
Discussion Starter #7
well i went again this friday and got a 14.81 @89mph 2.4 60ft still couldnt let the air out of the tires. it had a pretty decent tune in it and i limped the tranny note the mph is slower then last time but the et is faster guess im done for a while now
1 - 7 of 7 Posts
