1 - 7 of 7 Posts
Just Wondering If Anyone Has Experienced A Flat Line During Spool Up As If Governor Is Working Before Redline? I'm Thinking Fuel Filter But Would Like Some Input If Someone Can Help. Truck Has 74k
Fuel Filter is something many overlook but needs to kept after like all the others on the truck. I neglected mine and changing it made a world of difference! I forgot what a thrill it is when the tires break loose on the 3-4 upshift passing someone :D
Hi, I'm Earth. Have we met?
ah huh? i remember u were changing that thing when we went to ohio for the dyno! how long ago was that?
I change mine about every 7k and when i cut them open they are ickey inside. adding a lift pump made the filter discoloration even over the whole filter vs. just the bottom being discolored with out the pump!!:fart
Guilty as charged, that was umm.........3 months ago :rolleyes:
I think I had 18,000 miles total on it. 3,880 psi rail pressure means your not getting over the mountain on the way home from work at a speed more than about 35 mph. :eek:
1 - 7 of 7 Posts
