1 - 7 of 7 Posts
Can anyone help me out real quick. I'm in the middle of the install and I'm stuck at the part where you have to cut the middle section of pipe. I have the muffler level and ready to go but it looks way to close to the drive shaft and I want to be sure I'm on the right hanger which is the one if front of the rear end correct. Thanks in advance
when i installed mine i believe i had to swap sides for the hanger (closer to the outside of the truck) for it to look right. mine was too close to the driveshaft as well. im talking bout the hanger closest to and in front of the rear axle
Just so I'm following ya here you flip the hanger from the rear of the truck to the front correct?
Also do you happen to remember how much you had to cut of the middle as well it's looking like maybe 2" for me my trucks a CCSB
no. there should be two hangers opposite each other in the same area above the rear axle. in other words move the rubber hanger from where its at to the other directly on the other side and try that.
i think i had to cut around 6-10in. im not completely sure though. mine was an MBRP but still has the muffler. i'll try to get some pics later if u want.
if its not an 11-13 model though its gonna be different.
Discussion Starter #6
Thanks for the help. I managed to get everything lined up perfect and sounds great.
Awesome! Glad u got it figured out! :thumb
1 - 7 of 7 Posts
