1 - 10 of 10 Posts
Hot Rod Photographer
Is there a whip tucked away somewhere that I can tap into? I own the lt version and it doesn't have lights and I want to add them. Any thoughts. Or should I just go aftermarket on the bumper with some lights?
That's an idea. I might just use but do want control of them. Maybe power formthe relays from them. Thanks
You could use power off the lows w/ a relay. I have my fogs come on w/ my lows.
Do work!
Look at the "where to buy hid's" thread. I posted in there on a complete fog kit. I can't copy the link to here cuz I'm on my phone. If someone could that would be great
Sent from a combine cab using AutoGuide
03-06 CHEVY SILVERADO TRUCK FOG LAMPS LIGHTS KIT OEM GM - eBay (item 370532117527 end time Oct-02-11 11:07:33 PDT)
Mine was not prewired they said they should be in the description. But it was really easy to wire. I also didn't have to have it programmed to recognize the fog lights.
:thumb
I also bought mine off of ebay, came with the wiring harness that just plugged in to my relay box/fuse panel in the engine compartment. Then I just threw the new switch in and boom goes the dynamite!
Haha thanks man. Mine was the same way never had to get it programmed lol
No problem. You know, actually when I get to looking at that link, that's the exact place I purchased mine through. Highly recommended!
:thumb
YEP! This is exactly what I am looking for. Might need to wait till next month.. The exhaust and EGR blocker combined got the allowance this week.. I did sneak in some ECM pins from Idaho Rob though for the high idle.. thanks again man its book marked!
1 - 10 of 10 Posts
