my fog lights no longer work i have checked all fuses, relays and even put new bulbs in and still nothin anyone else had this problem?
· Premium Member
bad switch?? I dunno...have you tried check for power at those plugs? Possibly a relay?
yea i have checked the relay but i haven't tried checkin to see if they are gettin power down to the lights. its probably the swith because the light doesn't come on beside the button
if your relay,fuse, and bulb are good then i would say its your switch if you have a meter check to see if you have power if you dont then its the switch
i will check everything with a meter tomorrow. if my switch is bad has anyone hooked a toggle switch up to run them?
