1 - 12 of 12 Posts
Fox 2.0 shocks is what im ordered, i have 2" front 3" back, cognito uppers, stock will not work over extented, and there 1" over stock will not work, the next option is 4-6" which i ordered will this be ok? what are you guys running ? thanks
When I had my level kit which was 2.25" (front) and 0" (back), I had the following parts which were supplied by NorCal:
Front Fox 2.0 Shocks (part number 980-24-963)
Rear Fox 2.0 Shocks (part number 980-24-664)
Check those part numbers on Fox's web site and you'll see their lift recommendations are for 0-1", but they also supplied the shock extenders for the front shocks.
And by the way, these shocks came with NorCal's complete Stage 6 kit which included the Cognito UCA's, etc. The shocks however were stock length (or rather 0 - 1" lift) and just used shock extenders to account for the extended length to drop the from the upper mounting position by about 1.5".
Now, the 3" lift you have on the back is a new one on me... I might want to go for either the 4 - 6" rears shocks or modify the receiver brackets on the axle or... you have to ask someone else on that. HmmMMmm
ya hard to say, fox does'nt show the extended length and collapsed lengths of shocks
stock extended is -18.61
stock collapsed is-13.17
fox extended is-22.61
collapsed is-15.17
diff ext-4"
diff collapsed-2"
diff 2" collapsed and 2" lift in front should be fine what you guys think?
Fox 2013-2011 Front 4-6" 980-24-965
thanks man
have my tbars cranked way up and stock shocks are shot all the shocks i looked at seem really short that are made for a leveling kit i found some that are supposed to be for a 6 inch lift ....
Collapsed: 13.37
Extended: 22.18
so if you say
then those should be perfect right?
nevermind i see this thread is about 2011+ trucks ...anyone know the length on 01-10 trucks???
1 - 12 of 12 Posts
