Nothing wrong with going back to conventional, Rotella is an excellent oil.previous owner used mobil 1 syn 5w40 but i use reg 15w40 rotella in my equipment with lucas and would like to use the same oil in the truck,thanks
You should search for the Lucas write up someone did here,it is in the threads if ya search,bet you won't use it too much longer.........IMHO there is a lot better products out there....i have used lucas in every vehicle i have owned,and also all my equipment,even my toys and (knock on wood) and have never had an engine issue and i usually drive them 200k miles
You should check Tractor Supply then, I usually find it for the same price if not a few cants cheaperAs much as I hate walmart/sams, I am heading to sam's club in a little while to buy some rotella. They had the 2 2.5 gallon jugs for 50 bucks. $10/gallon. :rockin
If I ever removed my emissions crap I'll go back to synthetic.
I always forget about tractor supply and I am tax exempt (Farm use) and save another 8%.You should check Tractor Supply then, I usually find it for the same price if not a few cants cheaper
Also a plus is I do not have to deal with WelfareMart :rockin
