last week my truck started pulling to the right when I get to 8 mph and gradually pulls right till stopped . I did take all the brakes apart and even cleaned the abs sensors , I did replace the left sensor because the plastic housing cracked when trying to remove it .
Driving it today it felt like the pedal was coming back up . Im lost everything checks out no stuck calipers, pads are free and clean on the bracket .
Ideas please .
I will not have internet till next sunday , Ill check back then .
thanks , Drew
The was kicking back at you correct?
very slightly it felt like the pedal was coming back up .
Flush your brake fluid to make sure you have no line restrictions with fluid flow to any one wheel. Pulling right, it could be a left problem.
The rubber brake like to your caliper will get worn and collapse when you hit the pedal. Id definitely check that. That could cause it to pull really bad.
thanks guys Ill check all those out .
thanks Drew
