1 - 14 of 14 Posts
Check out the video below for an install video of it and link for the part. I had the same issue you are having when hitting a bump or something the steering wheel would go one way or another AKA "bump steer". I installed these brackets and it tightened everything up so no more bump steer.
https://www.youtube.com/watch?v=t8yy4rmJ1BI
https://cognitomotorsports.com/i-30...ubmodel=TRUCK||model=2500||make=GM||year=2008
Thanks man! Ill give it a shot. Is this something i can do my self or does a shop need to do it? I dont have a lift so idk if i can do it.
Lmm Guy
You should be able to do it. Just make sure you got a wrench big enough for the pitman arm nut. I got under there and started working then realized i didnt have a big enough wrench handy so had to go get one.
Will this kit work sense mine is lifted 6 inches?
Lmm Guy
That i am not entirely sure. I would call Cognito and ask them tomorrow. Also, kryptonite make some as well just so you have options. I run cognito tho.
Discussion Starter · #14 ·
Well turns out i had a bad inner tie rod in the driver ride. Fixed the jolt feeling but i still here somethint loose like its in the steering linkages but idk.
Lmm Guy
1 - 14 of 14 Posts
