My front end starting shaking around 60 and 80 mph... I had a new gear box replaced along with power steering pump, idler arm and pitman arm about 2 weeks ago... also there's alot of tension in the steering wheel. I can turn the wheel right no problem but turning it left is kind of difficult. .. when drivng the wheel will stay turned to the right alittle.. like something is pushing it.. the truck does not pull but will dift after acouple seconds of letting the wheel go.. mods are 6inch procomp lift with 35s and kryptonite tie rods
