Looking to crank up the torsion bars a little and noticed they were off from factory. Left wheel to fender 8" and Right 9" . Also rubber Jouncers were resting on bottom. Do I crank them to even it out? . Thanks
Thanks, I am suprised that my 08' drives and is aligned perfectly with a 1" difference between the sides. Now that I went up one turn on the right and two for the left (Trying to even the diff.) that it drifts to one side on the hwy.
Any time you mess with your torsion bars you are changing the geometry of your front suspension, so I couldn't recommend getting an alignment done enough!
Thanks , will do on monday, after I play with the height a bit
