my torque wrench doesn’t go that low. I’m going to buy a new torque wrench and re torque mine.Ok, so I'm doing this from memory, so the numbers might not be exact.
There are two different torque specs, one for the bowl, and one for the drain.
There is also a procedure, so 2+.5 Nm means first tighten to 2 Nm, then set the wrench to 2.5 Nm for final torque. The 2 Nm applies to the drain plug.
The bowl is 25 Nm + 5 Nm (once again, check what the bowl says)
2Nm is 17.7 in lbs
25 Nm is 18.4 ft lbs
