I have an 03 2500 HD Duramax. It has just developed a starting problem. I can pump up the fuel filter primer and there is a leak from the plastic fitting on the bottom. The truck will then start and run fine. When it sits for any length of time, I have to do this all over.
Do I need a new filter? Is this fitting built into the filter or does it get swapped over each time the filter is changed?
Thanks
Thanks
