1 - 20 of 23 Posts
Any one have a simplified method of changing the fuel filter?
Yeah i let my mechanics at work do it. Oil change, oil filter, and fuel filter, and CAT filter is about 85$. Well worth it in my book.
Change it yourself, It's sooooooooo easy!!!!!!! Consider installing a prefilter, less expensive and saves # of changes on the expensive factory.
I never bent my ac line. I have done it once with removing the battery and twice without.
Fuel Filter
I keep thinking I have enough room to get the filter out without moving the AC as well. My one problem is I can't seem to get the electrical connection under the filter to release when trying to get at it from above.
It is kinda tricky, but after working on the F-16 for 11 years, you find a way...thanks to engineers that only seen their stuff on CADD.
I take the connector out of the wire loop tie and use a screwdriver to push in the tab to release it while I pull it apart. You have to contort your body a little sometimes to get it. The first time was the hardest though.
I've never had to bend my A/C line or remove any parts. I find it easy to remove. The electrical comes unclipped very easy and the whole assembly just unthreads and drops down. Install new in reverse no problems, I wonder why so many have found this difficult, Is there a difference in where the filters are mounted from truck to truck?:confused:
Ive wondered the same thing. I drop my filter down
Discussion Starter · #18 ·
Fuel Filter
The Filters are all in the same place but the AC line that has been talked about is sometimes off by as much as an inch, giving one enough room to bring the filter out thru the top without bending the AC line.
I agree with rebel it is very easy to replace once you have done it a few times. It really shoudn't take more that ten minutes. The most time consuming part is changing the water fuel sensor over to the new filter. Good luck!
Discussion Starter · #20 ·
There is a slight variance in the A/C line location. Just enough to make the difference between bending it & not bending it. I could not disconnect the electrical from above. Any secrets to that?
1 - 20 of 23 Posts
