i recently installed a airdog. on my lb7 and i had snapped the plastic bleeder screw on the filter housing so a buddy thought hed help me out. to make a long story short. filter housing is striped out and a new one is 400 bucks. if i elimanate this how can i bleed the system to get the truck to run???
By the alternator there is a cap on the fuel pipe-- remove the cap and you will see a schrader valve-- you can bleed the air from there.
You installed an airdog.... No need to bleed the system, just let the airdog push the fuel on up to the system
yea i no the airdog will push the air out but what do i just turn the key and hold that schrader valve till solid fuel comes out? i wasnt sure if i could do that our i needed to hook somthing up there to suck it through the cp3
I'm That Guy...
It might start rough or die, but it'll clear the air out without any true bleeding.
