Hoping someone can give me some a solution. I have an 03 duramax that was running fine until one hesitant start, 5 seconds of cranking and it started, drove 5 mi home, checked wot to see if filter may be clogging, but no problem. Turned off engine ...5 hours later no start...cranks fine, scan tool says FRP 43...I get 2, check filter, no air, filter was clean. Air pressure in tank bled half a gallon at the filter in 30 seconds...Is their some electrical component that could suddenly fail that would keep the injectors from opening? Such as the fuel regulator?:help
