Next thing to order is a set of gauges and looking for something that may match stock cluster wanting boost, egt, and fuel psi. would like to see pics. of the different kinds out there that would help me a lot thanks
they look good but are expensiveIf you plan on keeping your turbo stock or run under 29 lbs of boost...
Check out Defi gauges....things are amazing looking and extremely accurate.
Had them in subaru
I think I'm just gonna go with boost and EGT. Fuel pressure is probably fun to watch but I'm not really going to be tuning my truck so I don't really need it. Boost seems important because if you're above the 35 range that's pretty bad, and EGT is important 'cause you don't want to melt your exhaust, lol. Fuel pressure... Idk... I guess it could hint you in on your fuel filter going bad before it does...Bump what should i go with 3 or 2 gauges
