Thinking I may need to re-gear with the new 4094vvt and 37" tires. What ratio should I go with??
DWILPAT · Registered Joined Jun 9, 2008 · 255 Posts Discussion Starter · #1 · May 7, 2010 Only show this user Thinking I may need to re-gear with the new 4094vvt and 37" tires. What ratio should I go with??
theunderlord · saw what you did there Joined Jan 14, 2009 · 15,168 Posts #2 · May 7, 2010 Only show this user 4.56 .
DWILPAT · Registered Joined Jun 9, 2008 · 255 Posts Discussion Starter · #3 · May 7, 2010 Only show this user Another stupid question.... What rear is in my 07 classic LBZ??? And which aftermarket manufacturer (ring and pinion) do you all reccommend?
M Meyerperformance · Registered Joined Mar 20, 2008 · 14,291 Posts #4 · May 7, 2010 Only show this user Aam11.5....
theunderlord · saw what you did there Joined Jan 14, 2009 · 15,168 Posts #5 · May 7, 2010 Only show this user yup. 14 bolt 11.5" ring gear. 3.73 Ratio. I have G2 Gears, cheaper than Yukon, more expensive than AAM. They're quiet. not much else to say really..
DWILPAT · Registered Joined Jun 9, 2008 · 255 Posts Discussion Starter · #6 · May 11, 2010 Only show this user How about the front??? 8.25 or 9.25?????
M Meyerperformance · Registered Joined Mar 20, 2008 · 14,291 Posts #7 · May 11, 2010 Only show this user 9.25.........
Smokin06 · Registered Joined Jan 14, 2010 · 119 Posts #8 · May 11, 2010 Only show this user I am also thinking about doing a gear swap did anyone notice a drop in egts or better fuel economy? I am goin with 4.56
theunderlord · saw what you did there Joined Jan 14, 2009 · 15,168 Posts #9 · May 11, 2010 Only show this user The truck drives much better... no real mpg inmprovements.
