1 - 20 of 47 Posts
What is the trick to getting the back two star bolts? I got everything else out but them back two HELP ME
Sent from my PC36100 using AutoGuide App
A lot of annoyance, anger, sadness, frustration, and pressure.
Not sure if your talking about the up pipe bolts, but if so you can fit a 12" breaker bar with a 12pt socket back there and alot of pushing should break them loose.
· Im Superrrrr!
Use some heat and some pb blaster.....
and a cheater bar
· Premium Member
Ok just broke loose the passage side bolt the way I did it was took battery box and inner fender out straddled the radiator area with a 12mm and mini breaker bar 3/4 drive and in that position I had the leverage and aero coil
if youre talking about the up pipe bolts there are three per up pipe so 6 all together
Discussion Starter · #14 ·
Ok got them how you get the inner two stars and lower two stars on the exhaust. I got the two outer star bolts
· Its just a worktruck
19 Sierra
You get to all six 12 point bolts through the passenger fender. Its easiest to have a friend to help. One guy to hold the socket on the bolt and one to push/pull up on the breaker bar. You might need to use a small extension for some of them.
12point 12mm with I believe a 3" extension on a 1/2 drive flex head retched is what I use I go from the top
19 Sierra
I was like rueful stick....what the hell is he talkin about? :rof
There's 2 bolts holding the dipstick. They are close to the top of the bellhousing on the trans. Gotta go through the fender to get them.
Discussion Starter · #20 ·
Ok hmm I'll have to look again. Then drop the down pipe right? Then the other star bolts will be reachable?
1 - 20 of 47 Posts
