glow plug delete kit
59K views 29 replies 13 participants last post by  silvergmc
I was looking on danville performance and saw they have a glow plug delete kit. Why would you want to delete your glow plugs?
So I take it glow plugs arent necessary for start up? Sorry for any dumb questions im still learning about these motors.
#4 ·
It depends on compression ratio and temperature. Most of the competition trucks run lower compression so a little ether might be needed if there's no glow plugs.
Thanks
#7 ·
Ya that was a pretty rough start. Will that mess your engine up after awhile?
Until you make your glow plugs swell up and they end up being too big to come out, so then you have to break them off into your cylinder, and you end up having to pull the head to get the other half of the glow plug out.
Nope... not bad at all.
#15 ·
Wow, for 2k you'd think he might have just been better off doing a valve job on a used set and swapping heads.
#12 ·
cranking/running with the glow plug delete kit won't cause any harm, other than hard cold starts, because it replaces the glow plugs with "dummy plugs"
Constantly starting a truck without waiting for the wait to start light to go off or not having an operating glow plug system (with the glow plugs still in it) makes the glow plugs to swell up at the tips. Ask anyone that has worked in a military motorpool. None of the operators wait for the wait to start light to go off, and the swollen tips happened constantly.
Reactions: RBen and BlownL36
#28 ·
Better tell GM. When started with the keyfob my stock 2013 LML starts before the light goes out all the time.
Assuming the glow plug is at its hottest point when the light goes out, how would cranking when glow plug is colder make it more susceptible to deformation?
#14 ·
Thanks for the info everyone. Learn something new everyday.
#17 ·
If I did that I wouldn't be able to use my truck all winter......definitely nice to be in a warm climate.
#19 ·
When we pulled my motor I found that I only had about 4 glow plugs working. I removed the glow plugs, cut the tips off and reinstalled them and I have removed the GPCM. As my truck will mainly be used in the summer for pulling and sit in the garage in the winter unless absolutely needed in the winter.
#21 ·
That shouldn't do anything other than make it a bit harder to start since the GP tips aren't up to temp yet.
#27 ·
several people I work with have disabled the glow plugs. lowest temp around here in winter is 28 - 29 degrees and that is rare.
#29 ·
I just snapped a glow plug right above the threads and currently have a local shop trying to extract the part of the plug stuck in the head. Welcome to Diesel Truck World, rookie (me). Wondering if I could leave it in there and hope the tip/part left in the head doesn't somehow fall into the cylinder (wondering if that is possible?) while driving. Any thoughts?
#30 ·
Unlike the old military 6.5 GM engines, a Duramax doesn’t have to have glow plugs to start unless it’s cold. The old 6.2, 6.5 engines will not start without them unless the engine has been run already and hasn‘t been shut off long or you warm it up some other way like a fuel fired heater. The main thing that swell glow plug tips are ether hitting them while they are hot or the relay sticks and they stay on longer than they were designed to. I have had to break off a glow plug tip on a Ford 7.3 IDI, not a Powerstroke, and then start it. The glow plug tip will “usually” either embed itself in the piston or get blown out the exhaust. Rarely I’ve seen it get hung up with the exhaust valve and cause problems with the seats.
