So I jumped a guy off at the mall a couple weeks ago and my check engine light has been on ever since. I can't remember the code but it's a glow plug fault on cyl. 3. Is the actual glow plug gonna be the problem? If I replace it should the fault clear? Guess I should replace all while i'm in there. Also, the glow plug coil will not go off when I turn the key on. If I crank it anyway and let it warm up it will go off as long as the engine is warm. thanks for any help
