Glow plug fuse keeps blowing, new glow plug /air intake heater controller and glow plugs. HELP
R Russ65704 · Registered Joined Jul 13, 2017 · 18 Posts Discussion Starter · #1 · Aug 31, 2019 Only show this user Glow plug fuse keeps blowing, new glow plug /air intake heater controller and glow plugs. HELP
R Russ65704 · Registered Joined Jul 13, 2017 · 18 Posts Discussion Starter · #2 · Sep 1, 2019 Only show this user New alternator and not charging batteried
stevewaclo · Premium Member Joined Aug 22, 2012 · 709 Posts #3 · Sep 3, 2019 Only show this user Another problem? Russ65704 said: New alternator and not charging batteried Click to expand... When it rains... Maybe start a new thread on the second issue. While the search function on our site is pretty useful, often a Google will turn up additional 411. Here’s something I found that may be helpful and I encourage you to search further: https://www.dieselplace.com/forum/6...004-lb7/339637-keeps-blowing-175amp-fuse.html In my limited experience, I have not seen many (any?) reports of trouble with the glow plug fuse blowing. Best
R Russ65704 · Registered Joined Jul 13, 2017 · 18 Posts Discussion Starter · #4 · Sep 4, 2019 Only show this user Thanks that is exactly what my fuse is doing, will check tmro, now to get my batteries charging. Thanks again
R Russ65704 · Registered Joined Jul 13, 2017 · 18 Posts Discussion Starter · #5 · Sep 11, 2019 Only show this user You were right when I tightened the nut that holds the buss bar it bent and was touching the exhaust . Thanks again
