1st how do you check glow plugs, any pics on the site ,if so please send link, i am trying to get the connector off the glow plug relay but cant figure it out, how to do it, please help
thanks
You have to release the tabs on the female connector,then pull it apart.Use a 12 volt trouble light & check the small bar that runs accross the tips of the heaters.You need a special volt meter to check the relays.they have to be taken apart to do it & 12 volt run to them at different points on the connections,if you dont understand it dont try it,you'll smoke the realys.take it to someone that knows what there doing.
what code are you throwing? I just changed glow plug 3 p0673. I figured since it was just one glow plug that wasn't working i would just buy a new one.
