Would anyone happen to have the directions for removing and reinstalling glow plugs for a 2003 Chevy Duramax?
Same thing!Ever do spark plugs on a gas engine? Same thing just with a wire screwed on with a nut. Simple to do. If you never did them might be easiar to remove the inner fender first. Even if you did them before remiving the inner fender makes it simple.
How do they know the tip fell off? If it did wouldnt that cause some damage to the cylinder, piston and head?My dealer just called and said the small tip came off the glow plug and they must remove the head. Can this happen? and if the tip does break off must you remove the head?
I replaced #5 glow plug and this was not the problem.
Can anyone tell me how to check the Glow Plug Control Module to see if it is working. I know that each glow plug is on an individual circut.
