Woah.. I had that on our 2012 2500LML.. they warranted the GP longer because it was their issue and they owned up to it. For a LOT of the LMLs.
What a huge pain to have the truck down when you are depending on it.
The GP would fail in “startup”... always when I would get in truck when cold and quickly spin to crank it. I firmly believe it was the BCM for the GP that caused over current to the GP during the initial start sequence from the ignition key turn. In fact, when I told the GM Rep my thought on the cause, he actually stammered.. started blinking his eyes... I thought for the moment he might be ill... nope, busted. At least regarding my truck. I am sure I am the only one to have considered...
There may be other causes... sure, but for it to be so specific, and other possibilities eliminated, well, “It is elementary, Watson.” I forget who said it.. “When you have eliminated every possible cause and reason, whatever remains, no matter how impossible or improbable, must be true.”
the truck had other issues.. the driver seat cooling fan Module self destructed... the collision features, airbag, steering wheel and side pillars, other emission problems as widely experienced and stated .. burned thru DEF like .. well, a lot...
On one occasion DEF used up100 miles from limp mode in a little over a tank of fuel. (Got fuel at a mom-pop store up in Arkansas back water... ) and it had “that smell” of different fuel. A couple tanks later the fuel filter was done. Not GMs fault there.
But it pulled very well... until abandoning us several times, states away from home with GPs and NOX sensor failures..
It became a good “farmers truck” and is happily rolling out the rest of its life after being neutered (deleted) and no longer licensed for the road. Or so I hear...
