1 - 20 of 20 Posts
Does anyone know the process of which GM fixes the head gaskets on LLYs? Specifically if they lift the cab off the truck?
Some lift the cab, some remove the front clip [fenders radiator and etc], and some just lean over the fender. It all depends what the mechanic wants to do.
I removed the wheels and dropped it on the spindles, when I did mine- Preventive Maintenance-- [I was 75 then Ha Ha].
No need to lift the cab. Pull the wheels & get the truck as low as you can.
Never heard of people dropping the wheels off. Makes sense though. Is there an "official" way that GM recommends?
Gm will lift the cab
So when the standard labor times go from 30-36hours to complete the job, is this in terms of lifting the cab? The reason I ask is because I plan to change my gaskets and stud my heads and am trying to figure out if I wanna pull the engine out or lift the cab.
I'll be doing an EGR delete and installing a down pipe too while im in there
If you have a lift I think it would be easier to lift the cab. I hate separating the engine and trans and re-connecting, that's the worst part IMO.
I have done plenty without lifting the cab just flatten the front tires and take the inner fenders out
Yeah I have access to a lift, so maybe I'll do that.
Though going back to pulling the engine out, I was considering maybe replacing my rods with LML rods but im not sure if this is worth it or not. Any thoughts? No plans on racing, just keeping my truck for several more years
If you do the rods you'll have to have the whole rotating assembly balanced. I don't think it's worth it personally. If you want to do rods save up and do some good aftermarket ones.
Yeah aftermarket ones are completely out of the question right now so thats why I was considering the LML ones since they arent expensive at all. But like you said, doesnt seem worth it unless I do go the aftermarket route.
So when people pull the wheels out when doing head gaskets, is this literally just to make the truck lower to the ground just so its easier to reach?
Yep. You can remove the wheels and put a 4x4 under the control arms and basically set the truck right on the ground.
Discussion Starter · #14 ·
Interesting.
The only problem now is im trying to find a set of stock heads to put in so I can just immediately swap out the heads and put the studs in without much downtime
Forgive me for the thread highjack but I am in the same boat with head gaskets right now. I am planning on doing my own Dye Penetrant test and flatness check on the heads. Any thoughts out there as far as where to look for common crack locations, specs on flatness?
Discussion Starter · #16 ·
Do you have your heads out already?
No, this weekend or next. I ended up having to do this work myself because there is no one local that can pressure test and I should be able to do the other two checks myself for free.
Looks like a hell of a job but I can't afford the $3800 to have done.
It's not a hard job, it's just time consuming taking off the 38 layers of crap stacked on top of the engine.
I just got mine back together. Each has his preference, but if ever do another one I will probably do the same thing I did on this one. I removed both front fender (not too bad to do) then after having trouble getting a couple of exhaust bolts loose, I lifted the cab about 4 inches. Didn't remove the cab, but a few cab bolts and a jack and you can raise a cab in about 20 minutes and give yourself much more access to the back of the engine.
Discussion Starter · #20 ·
How long did it take you in all?
1 - 20 of 20 Posts
