1 - 20 of 30 Posts
You better watch out for the 5-6 shift especially with the 37s. To run a 14 you will need to be on it pretty hard.
The quad on 135 is useless with out a lift pump IMHO
that tacoma prolly runs 11's right?
NewEST Spinny Thinggg
110 tune and boost a little big tires will still hook usually
I would agree on the 110. The 135 will be starving for fuel at the higer Rpms. I ran my diablo at 120 when I had it and had the same problems.It would perform nearly as well on the 85 because the fuel was there at higher Rpms
When i ran my truck in 2wd all it did was spin, But of course your tires are considerably bigger!
2020 GMC 3500HD AT4 L5P Diesel
TANK,
Going to Mason Dixon? Over the mountain on 40?
Discussion Starter · #15 ·
OK so good night, I shut up a bunch of dudes running there mouth about how chevys suck and there 6.0 was sick.
First run 110 tune 2 wd
15.928 at 89.92
Second through fourth run 135 tune boosted 4wd launch
15.405 at 89.46
15.125 at 89.71
I got in the 14's.
14.92 at 89.71
Same mph as the 15.1 run.
Truck pulled really strong went straight off the line I think it really helps that my cv angles are almost flat.
15.928 at 89.92
15.405 at 89.46
15.125 at 89.71
I got in the 14's.
14.92 at 89.71
wow not bad at all with what your running on there
dang tank the quickest i could run was a 15.2 but was scared to even try it in 4wheel with my lift and 37s even seein you do it with success still makes me scared ill blow it up haha
15.928 at 89.92
15.405 at 89.46
15.125 at 89.71
I got in the 14's.
14.92 at 89.71
thats seems pretty damn quick for a big truck on 37's!!!
1 - 20 of 30 Posts
