Hey I thought our trucks only had 11 grease fittings but while changing out my rotors and pads I noticed fittings on the calipers. Are these supposed to be greased regularly, and if so, with regular grease?
Sounds like a bleeder screw to me! You will should never need to bleed your brake lines unless you loose brake pedal or need to replace a brake line or caliperNever mind. I guess it is the bleeder. Do you have to break this loose a little to bleed the brakes?
