1 - 10 of 10 Posts
its a good reference, thanks
Lots of info in it. :thumb
Good find, good read.
From page 6,
"While most fuel filters recommended by engine manufacturers have a nominal pore size of 10 microns, 6 studies by the Southwest Research Institute reveal that the critical particle size for initiating significant abrasive wear in rotary injection fuel pumps and in high-pressure fuel injection systems is from six to seven microns."
What is the stock filter rated for? I'm glad I switched to the CAT/FASS combo!
I believe I've seen it on here somewhere, but can't have too much info.
The Racor PFF50216 fuel filter (supposedly, the same GM filter part# 12633243) has a micron rating of 4 according to Racor.
So I now know why diesel is more expensive than gas. Awesome article thanks!
1 - 10 of 10 Posts
