1 - 20 of 25 Posts
This morning I elected to do this mod, which took about 90 minutes total. For those of you with smog inspections, who do not like taking on/off your CAT with a delete pipe, and who would like to save a $100.00 for the delete pipe, this mod is for you.
1: Remove the four flange bolts/nuts holding your CAT to the rest of your exhaust system. In my case, I have a DPF delete pipe.
2: Loosen and remove the band clamp that holds the CAT and down pipe together. Use caution, so the CAT pipe doesn't bump you in the head.
3: Previously, I had removed a transmission bracket that holds the CAT in place. I removed this, so the CAT can be removed. Just rotate the CAT and it will drop right out.
4: Using a hammer and a 18" breaker bar, I pounded the honeycomb crap out of the CAT. Once you punch a hole into it, the rest will easily break up and fall out. You won't believe the crap that comes out. I can't believe the exhaust can flow through that honeycomb stuff.
5: I elected to wash my CAT inside and out, which cleaned out all the black soot. I used some Aluminum wheel cleaner, which made the CAT look brand new.
6: Re-install your CAT and enjoy.
That's the shit that came out?!?! Wow that is amazing it flows through there!
And that's a pry bar not a breaker bar lol sorry I had to
I know.....I was fricking stunned my truck could still run with that crap in there...lol.
· Premium Member
I am curious if you can notice the performance difference, after the modification.
· Premium Member
I had a Tahoe I gutted the cat on. The exhaust sounded funny afterwards. Is there any change in the exhaust note?
· Premium Member
I did mine in about 40 minutes, just unbolted the rear flange, popped the rubber hangers off the muffler/pipe and used a long 1" spade bit to chew out most of the "stuff" followed by a pry bar and vacuum cleaner, then I started it up, blew out a bunch of "stuff" and reconnected the exhaust pipe and hangers. A little brake fluid helps to get the hangers back on.....
· Hot Rod Photographer
Did it on my old superduty.. The tone changed a little.. Thank god I dont have that 6.slow anymore.. What a piece of crap that truck was..
Yes the tone changes more "flow noise"
· Premium Member
I have gutted several cats before, mostly with a Rage 2 blade though. :thumb
is there any codes that can be throw with gutting the cat.
Let us know what change you see in your fuel economy, if you would, please.
why not buy a delet pipe and just remove the cat . so if you ever need it againe you have it they are really resonable 100-150 and the delet pipe doesn't have any bends which will flow better
· Premium Member
I have never had any codes in 20,000 miles, much of it towing. I don't notice any real MPG difference, but EGTs are lower by about 100*.
Discussion Starter · #18 ·
Guys, the truck sounds awesome. Like a fricking jet plane when you get on it. When just cruising around, the exhaust is not loud or obnoxious. At idle, the truck sounds like a big block Chevy. When slowing down to a stop, you can hear the turbo whistle. Driving on the freeway on flat stretches, my EGT's are at or just below 500 degrees. Very happy with the results. I will be going back to my local dyno shop and see what it will do. The hp and torque in my signature was with the non-Race PPE Hot+2, which was through the CAT and DPF. Now my wife on the other hand, makes fun of the stack exhaust and the whole "diesel thing." I've threatened to put a stack on her Mercedes :D
· Premium Member
Just picked up an extra Kitty today....Going to do this mod on my spare Kitty this weekend.
1 - 20 of 25 Posts
