1 - 14 of 14 Posts
I have a new set of 18" denali rims and i need to order new tires but im not sure what size to get..... i was thinking 295/65/18 but im not sure what would be best. Im purchasing the cognito leving kit and want to put the biggest tire possible but with no issues of rubbing and whatnot. :thumb
I put LT285/65r18 BFG AT KO's. Stock height, no rub.
295/65-18 are actualy only 1/2 taller than stock. you can easily fit 295/70-18 on stock rims with a leveling kit. I have them on mine and I'm running a zero offset only had to do very minor trimming. Stock rims are like +30 something offset so you might not even need to trim. Hear is a page so you can compair sizes. Tire size calculator
Thanks, I'm ordering the cognino UCA's fox shock and pitman/idler arm braces before I do the tires. I was thinking of going with a 33"x11.5. Is that smaller or larger than a 295/70/18?
That is smaller. 295/70 come out to 34.5. I don't have the braces. Do the make much of a difference in handling?
here is mine. the rims are 18" tires are 295/70-18's with level keys and shock extenders
That looks sick!! I haven't done the braces yet so I don't know how much of a difference they will make. There more so you don't wear the idler arm and pitman arm out. I can't find any brands that make that size tire, what kind are they??
They are nitro Tera grappler's they also make them in the trail grappler but those are more of a MT and I wanted an AT.
hey op you best have some picts up when you get them :)
Do you know if those rims are bare polished aluminum or are they clear coated??
I think just polished aluminum, have not looked real close but i doubt they are clear coated. Stock GM rims though.
They are clear coated. For longevity.
I would assume they are, but up close they dont look like they are.... I'm gonna take some polish to them tomorrow and see if it comes off clean or dirty.
Discussion Starter · #14 ·
The rims are definitely clear coated....just tested em out with some mothers polish and the rag stayed clean. Im pumped cause now i dont have to worry about running them in the snow :thumb
1 - 14 of 14 Posts
