I have a 2002 6.6 that has been pushing out coolant intermittently over the past few months.when I fist notice I was driving and pulled up to a red light the temp dropped and the heat started blowing cold,as I pulled away from the light the temp went up and heat returned.I pulled over and saw large amounts of antifreeze leaving the overflow.
I have replace thermostats,overflow cap,and flushed heater core.each time it seems to resolve the issue for a few days then it starts again (as if it needs a few days to build up pressure).truck is scheduled to go into the dealership for new Hg's but I'm being threatened that if that is not the issue I will be stuck with the bill. Is there anything else I should look at that might cause this issue before getting the tear down?
Also any recalls that I should be aware of that might need to be addressed? I see a lot of people talking about injector cups?
any help would be greatly appreciated
Thanks.:help
Thanks.:help
