1 - 11 of 11 Posts
does anyone have the head torqure pattern sequence or does the ARP studs come with it?
i went straight to 125, then loosen all the way. on the third cycle i was done.
I mean torque pattern as in the sequence not the ft lb numbers
Probably not helpful, this is the LLY '05 for wot it's worth
are these ARP directions?
It's a scan from the GM Service manual. I would imagine that the torque sequence would be the same no matter what as the sequence has nothing to do with the bolts and everything to do with the head.
This should be the sequence for all years using the ARP head bolts.
1 - 11 of 11 Posts
