My truck is running fine, but I have a feeling the head gaskets are going. My truck has 87k miles on it, and still has the egr also. My problem is the hard upper hose. the trucks heat works just fine, never gets cold ect and my temp guage seems to be working normal. the truck has never gone over 210 all summer. I first noticed the stiff upper hose last spring. The trucks building alot of pressure in the cooling system, but it hasnt puked any anti freeze out. the level has stayed the same and I cant see any bubbles in the resevoir while running. obviously I'm some how building pressure in the cooling system, but I cant believe its not puking anti freeze out. the upper hose is about as hard as a rock. Does this sound like its absolutely a bad head gasket, or is there a chance its something else? from the egr cooler or a bad thermostat or anything? Thanks for taking the time to read through my novel!:drink
Jason
Jason
