on sunday we replaced the injectors. it wouldnt start then. we read 800psi rail psi. so we figured the fpr was bad. we changed both the fpr and the cp3 pump. it still wont start. any ideas?
did you bleed the injectors?
On top of the fuel filter there is a bleed screw, did you open the screw and bleed the system? I assume you filled up the fuel filter when you changed the injectors also before putting the new one on?
