1 - 2 of 2 Posts
I have a 2005 LLY and both my ABS and Parking brake light are on. The parking brake light will come on once i start moving. I dont know if they have a special relationship between the two or if both my ABS sensors and my Parking brake sensor are bad. PLEASE HELP ME!!! thanks
The parking brake light also tells you when something is wrong with the brake system.It may be something grounding out, but at the least I would check out all the brakes and make sure everything is good. Also if you can get someone with a V2 or Tech2 to read the ABS codes, and any other codes, that would definitley be a good place to start.
1 - 2 of 2 Posts
