1 - 11 of 11 Posts
inj have been done so that is a good thing. I think the price might be a little high but someone else may chime in with a diff opinion on that.
For a 02 that's had a life of pushing snow and heavy hauling i would pass on it. Also he never mentioned anything about getting new injector yet. For that price you can get a decent lly.
yes, i had read up on the injector issue, and i passed up a bunch of trucks that had original drippy injectors.
out of curiosity, they did fix that issue with the new injectors right?
INJECTORS HAVE BEEN DONE UNDER WARRANTY ABOUT 20K MILES AGO AT QUIRK CHEVY.
he said he used it for his driveway only. it has no gooseneck hitch.
also the LLY has overheating issues as far as i am aware?
i think its high too, unfortunately, i cannot wait.
i have tried every tactic to get him to lower the price with no luck.
i tried to get him to throw things in for free, everything.
i wanted it for 15K, but it does book for close to 18K.
They still have not got the issue corrected. They did . pdate some parts but still have a high failure rate. On the lly as long as you do the mouth piece its a good motor. Just make sure it don't have a leaky head gasket
mouth piece?
for the headgasket test would you say a cooling system pressure test is what i need or something else?
called chevy and had vin checked, injectors were replaced in '09
said no major engine or tranny issues.
steering linkage, window regulator, ect.
i guess i should also be asking, should i do anything to this truck before i gross 26,000-36,000 everyday?
1 - 11 of 11 Posts
