1 - 20 of 26 Posts
· Premium Member
this morning i went to install another tune and when it was counting down from 15 at the end of the tune it froze, now when i try to do anything with it it has this weird thumping sound in the dash and wont go past the first screens or any thing. also the ppe screen will flash dark to light:booboo:help
does the truck start? and run
well sucks buddy. but you need to have her towed to a dealer to have the ECM reflashed and you need to send the PPE back to PPE to have it unlocked
i did it to myself also. dont feel bad. it costs about 100 bucks to have the reflash. well thats what it cost me anyways. try unhooking your batteries for 30mins and then try it. but i i doubt it will work
· Premium Member
the ecm just needs a reflash or a totally new unit? this sucks never had this problem. i can put head gaskets in myself but throw a ecm problem at me and bam im the idiot.
you ecm just needs a reflash. thats all the ECM is not bad
i did the samething i did my head gaskets and then tuned my truck and then i changed tunes and the tuner cut out on me and bammm no nothing.
i would ditch the PPE like i am doign and get EFI this way you can reflash your ECM by yourself. you just load the stock log file back into the ECM
This happened to me also, i must have gotten lucky cause all i did was wait a couple minutes plug the tuner back in, put it back to stock then loaded the tune back in and it was fine, i guess i got lucky LOL, good luck man!
· Its just a worktruck
19 Sierra
go into the diagnostic menu and select return to stock. Not in the tuning menu. What did you have plugged in? cell charger maybe?
does your seciruty light flash at you when the key is on or when you open the door
1 - 20 of 26 Posts
