Hi All,
Truck: 2003 lb7 4x4 105000 mi, stock
Finished buttoning up my injectors last night, started it up and idle's rougher than a rabid ape in an oil drum. I read a few threads where guys had this problem, and said it came out of it, just had to get the air out of the system. I started and stopped it, primmed again, started and stopped, probably 15+ times, as well as let it run for a while. It pulls out of idle and smooths out by 1000 rpm and runs fine, but just can't idle.
It throws a p0193 (fuel rail pressure sensor circuit high input). The only other thing I just though of is that I hadn't hooked up the maf (?) sensor on the intake yet, but I don't think that would have much to do with it not idleing.
I checked all connections and fuel line fittings, nothing loose or leaking. It starts every time without a problem, idles nice for 2-3 seconds, then goes into the rough idle (almost feels like its on 4 cylinders)
Thanks guys!
Thanks guys!
