Hey guys my wife was starting down a steep grade of highway and the tranny clunked bad and set off the check engine light and the gear indicator light said it was in park and the brake light was flashing. Truck stayed in normal gear sounds like it tried to down shift for the downhill grade. She pulled over immediately shifted it into park and shut it off. When she went to turn it on it would chime and have lights in accesory but no power and dim to no check engine light in the on position. I show up and get no power anywhere when I try to get a code. Had it towed . Jumped in after still just power on accesory and dim gear lights and nothing when in the on position. Jumped in 3 minutes later and power to everything started right up and got a p0700 code only. Cleared it and everythings fine. Afraid to drive it. Also for the past month when I shift from park to a gear it makes a bad clicking noise by my newer nsbu about 50 percent of the time. (Driveway is a hill but happens even when on flat ground) And the past week ill pull up my street which is steep and stop to reverse and the tranny will clunk when I come to a stop without it shifting gears or me shifting into reverse. Please help! Need to truck this weekend.
