1 - 8 of 8 Posts
So here's the deal, I'm driving along put on my right turn signal and it the lever goes down. I then realise my turn signal light is on, not blinking or anything just stuck on. ( front,rear,mirror and dash)
-35 outside and don't have access to shop space till Monday. If I'm going out there I wanna know what I'm looking for. I've let it sit for 1 hour and the problem was still there.
Any help would be great!
If you move the lever, does the left side [driver side] work OK-?? At -35, I would wait until you get to a shop.
Works normal, if I click the passenger side it blinks once and hazards blink normally ( the lights just get brighter never fully go out on passenger side)
I had a simular problem im my grand am. after alot of use the brass will wear off the contacts inside the blinker lever and mix with the dielectric grease causing a complete circuit. remove the multi function switch from the column, open it up and clean out all the dielectric grease, reapply new grease, reassemble switch and test. good luck
The flasher is behind the dash close to the light switch.. It is a box looking part and nothing like the old round flashers.
1 - 8 of 8 Posts
