I popped the ball joint loose but now that castle but just spins and spins. What am I doing wrong?
When you take the nut partially off you can let the suspension hang. The UCA will stop at the frame stop and you can hit the knuckle with a hammer to separate the ball joint from the knuckle and the nut will stop the LCA from falling to the ground. Just put a jack under the LCA barely touching the LCA.one more thing for when i do the other side
why do all the directions say to only take the nut partially off? if i had taken it all the way off, i wouldnt have had any trouble. i supported the a arm/hub assembly with a jack as shown above.
if i attempt this again, is this the route to go?
