1 - 2 of 2 Posts
Hi guys I recently had my 8 injectors on my LB7 replaced under the special policy warrenty from GM an the had to replace 3 return lines during the install, my question is should'nt this be covered under the warrenty with the injectors because if the injectors weren't defective the lines would'nt of been replaced, I'm not sure if they had problems getting them off an wrecked them or what.
Also does anyone have a number for GM that I can call to talk to them about this? Thanks
The dealership tried to see if Gm would take care of it an it was denied- so it will cost me $238.13 for the 3 return lines.
The motor itself has a 100k warranty. If you exceeded that, well threre noting that could be done. I doubt they wrecked them. what happens is that they rust up on the ends and wont seat properly. And just to let you know, they cut you a deal because they normally go for $90 each.
1 - 2 of 2 Posts
