OK the problem is if I try to start the truck the starter just spins, i might try starting it 2or 3 times and itll spin then the next time it will start, then it might start the next few times then the starter will spin again? I replaced the starter still didnt fix the problem, I have a sb clutch and flywheel that havent been in even a year yet. Could the flywheel gears be stripped?:help
