Need help adjusting my valves, I have an AFO cam and the firing order is different. I was following the tradition firing order and having issues, until it dawned on me. The AFO cam firing order is 1-5-6-3-4-2-7-8
When cylinder 1 is TDC I can adjust cylinder x,y, and z intake exhaust valves, and so forth. that's the help i need, i cant find any info. Thanks
Discussion Starter #2
figured it out:
Rotate the engine and adjust one cylinder at a time.
When the exhaust valves just begin to open, adjust the intake.
When the intake valves are just past maximum lift, adjust the exhaust.
When the intake just closes, adjust the exhaust.
Both ways work, right? Are you saying I need to redo my exhaust valve lash?
Bump...
