1 - 13 of 13 Posts
I did a search and could not find anything. Could someone please explain where i need to drill and tap for the boost tube on my LBZ. I got some new gauges and just got my pillar painted this week. So i would like to get them installed as soon as possible. Also where is the best place for the power, ground and illumination wires?
If anyone has any pictures that would be very helpful.
Thanks in advance!
That is perfect! Thank you. Now does it really matter if it is drilled and tapped on the top, side or bottom?
I don't see why it would, but I have an LB7. I'm sure someone with an LBZ will chime in.
Also, is there a trick to get the boost tube to stay snug into the fittings so it wont pull out?
· AKA treyfox11
trace no call ?? when you tighten the nut the ferrell swells around the tube and holds it if it pulls out you didn't tighten it enough
· AKA treyfox11
the boost is picked up from the intake above the egr motor it is best to remove it to drill it
I gave you a call yesterday Trey, check your messages. So just hand tightening wont get it snug enough? Because thats all i have done so far just messing around with the parts. I have not installed them yet.
· AKA treyfox11
also i don't like where they are tapping in that link , its out in the open and very noticable , i like a cleaner look . Where i am doing it you can't see it
where else to you suggest tapping it?
· AKA treyfox11
yeah i got that call, my p.m. from last night said you would call today sometime sorry i havent been available , i have been out of town with wife for her birthday . lol you know how that is .:drink
Its all good, my V2 and DSP5 should be here tomorrow and im off work tuesday so i plan to install everything tuesday.
1 - 13 of 13 Posts
